Coil Ohm Range
trailshredder
Car: 1997 Q45, 175k miles
97 Q45, Just did knock sensors, cleaned plenum, TB, EGR and all new gaskets including valve cover gaskets, cleaned MAF. Still have a miss/stumble at idle. Pulled all coils off and they range from 1446 to 1534. FSM says if 0 ohms, replace. I have read other posts that mention a range to be in. Any real data on this? All these coils look acceptable to me but I see where numerous people have replaced all 8 coils to fix the miss/stumble. Thoughts?
Q451990
Do you have the dreaded "random missfire" code?
Heath
trailshredder
No Code, just the miss/stumble at idle.
Q451990
From what I remember, all of the coil issues come with a missfire code... I'm guessing that if an ohm test was a good way to test the coil packs it would be in the service manual, but I can't swear to that.
Heath
