Drift »
https://forums.nicoclub.com/drift-u3827.html
Thu Oct 30, 2003 5:25 pm
If your getting spark to the distributor, then check each spark plug wire w/ its plug and make sure you are getting spark to each plug. If one of them not sparking then you can check the plug, wire, or its section of the cap. If you are getting spark to each plug then you need to check your timing. Trust me, I had this same problem. When rotating your cas, did you mark where it was set before for the appropriate ignition timing?
