elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Aug 12, 2013 5:42 am
On a 96 the injectors would definitely be more likely, as 90-96 coils as you said seem to be good, however I wonder if the 96's were close enough to the 97-01 that they may be suspect???
If you want to try and isolate each cylinder, I'd just unplug the connector off each coil. All you'd have to do is take off that little plastic piece off each bank. I don't think what you're suggesting I'd feel comfortable with, I believe all that stuff goes back unfused to the ECU so that means you could short stuff out easily if things didn't go exactly as planned.
If you have a consult or take it to a place that has a consult, you can turn off each cylinder one at a time (power balance test). Maybe a standard OBDII code reader could do that?
Normally if an injector is bad it ohms bad, and if you listened to each one, almost has to be a coil?
