I have a Nissan 2001 Pathfinder I bought new in 2001, but it was actually manufactured in early 2000. Currently only 61K actual miles. I have read in the past that this new model engine, 3.6L, has a history of MAF and coil problems (one coil on each cylinder). So far, the 1, 2, 5, and 6 coils have failed between 42K and 61K miles. The MAF failed at 59K miles. Fortunately, I have an engine analyzer that identified the coil failures. Unfortunately, for the first 3 failures, I bought after market coils that seemed to really screw up the ignition system and resulted in many other error messages. These finally cleared up when I replaced the after market 1, 2, an 5 coils with OEM parts. The MAF failed such that it wouldn't pass the Denver area emission tests. I took it to a shop that identified the problem as the cats. The replacement cats were really expensive, so they welded in new cats for $1000. This didn't fix the problem. I took it to the state emission testing lab that told me the problem was the MAF. I took it back to the shop, they were kind enough to reverse the cat charge and replaced the MAF for $800. They used an after market (probably remanufactured) MAF that lasted less than 2000 miles. I replaced it with an OEM MAF myself for $200. So far so good, but only a few miles.
My questions are:
1. How common are these failures?
2. Is it because I bought a VERY early 2001 without the bugs worked out?
3. Should I replace # 3 & 4 coils now?
4. Has Nissan fixed the coil problems so the new coils will last, or is it a general ignition problem causing the failures?
5. Has Nissan fixed the MAF problems?
6. Do I have any recourse with Nissan?
I really like the SUV when I runs OK (250 HP with manual 5 speed), but these problems are becoming very annoying.
Rick
