Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Nov 22, 2004 7:54 am
i've seen many wild things in the land of EFI. Ever wonder why a fuel pump doesn't turn on sometimes? One possible culprit could be the ECU has a fugged circuit and can't ground the pump (ask SeVa S13 about that one)
A bad circuit could easily cause this problem. That's why I would try to get a friend to loan you his ECU so you can check to see if number four starts to fire properly. If it does, you need to get yourself a new ECU
One last thing I just now thought of, and it's a fairly base question to ask, but it should be asked. Have you changed spark plugs? If you're just saying "well, number four plug has a ton of gas on it, so the number four pack isn't firing right" you may want to consider a new plug if you haven't changed the plugs since you got the engine (i always recommend putting new plugs in a motor that comes out of a junkyard)
