97ExCab4x4 »
https://forums.nicoclub.com/97excab4x4-u225430.html
Thu Sep 19, 2013 11:08 am
Hi folks, I am new to the forum and a new owner of a 97 hard body, 4x4, 4cyl, 5 speed.
But I am by no means a new nissan owner, I started with a 88 hard body, moved to a 96 maxima, was blessed to own an 07 marrano and now have the 97 pick up.
Like I said, I recently bough the truck and forgot to notice if it had a catalytic converter, it does not!
I had the codes pulled the other day and they show codes:
420, which is a catalytic converter code I think?
440, not enough vacuum pressure?
and 446, purge solenoid?
My questions to you fine folks are, do you think all of these codes are due to the lack of cat? And if not what could I do to fix this? And am I doing any damage to the vehicle by driving it until I fix it?
My plan is to get it to the muffler shop asap. But I live in a rural place so emissions test are not an issue.
Oh, I guess I should mention the truck has 200k and it tops out at 60 mph, and sputters at random speeds. And backfires when slowing down while shifting from 1st to 2nd gear. And the gas mileage is worse then my v8 ford used to get.
Thanks for any advice!
97ExCab4x4 on Sat Sep 21, 2013 4:37 pm, edited 1 time in total.
