Codes P1320 and P0304.
pa2000cer
Car: 99 Infiniti I30
My car runs great for about half a day when I turn it on in the morning. Then, if I turn it on before it cools all of the way down, it runs and idles horribly. I got the ses codes and they were P1320 and P0304 and I have a few questions:
1) How do I know where the 4th cylinder is on my engine?2) Where is the best place online to buy the coil pack?3) Do I need to replace my O2 sensor as well?4) Should I do a resistance test on the coil pack before I do any of this?
Any help would be greatly appreciated.
Thanks.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
http://www.nicoclub.com/FSM/maxima/1995/st.pdf
You might try to work your way back to your model and year withthis
1)Also look in your owners manual for a diagram of the enginewith the cylinder #. I know it was in mine
2) I only trust OEM coils
I will try to come back with more info on 3 & 4
Mike G
Car: 2001 Infiniti I30
Numbers 3 could be a resulting condition from the failure of the coil pack.... I would iron that out first, run the car for a couple of days, clear the codes and go from there.
Just my $.02's --Mike
pa2000cer
Mike G, just to be clear...you would change the O2 sensor or change the ignition coil first?
Mike G
pa2000cer wrote:Mike G, just to be clear...you would change the O2 sensor or change the ignition coil first?
Ignition coil first, that would more than likely lead to a rich condirtion in your exhaust system, causing the O2 to pop...--Mike
