hitlayers wrote:OK so I found a buddy that has an OBDII diagnostic scanner and he cleared my check engine light, if I go to get it inspected with these codes, what are the chances it would pass?
There's a 0% chance you will pass. Even though you cleared the code and the SES light is off, the ECM is running tests on the O2 sensors to see if they are functional and to see if the system is running properly. Once you take it to get it inspected they will hook up a computer to the OBDII port and see that the system is in a NOT-READY state and it will fail.
Even if your O2 sensors were brand new and functioning perfectly, once you reset the DTC code it will check to see if everything is working properly to see if the issue was repaired. Even brand new O2 sensors would fail until the system put them into a READY state.
