kenshin3 »
https://forums.nicoclub.com/kenshin3-u308565.html
Tue Jan 09, 2024 4:17 pm
So I did a valve cover replacement 2 days ago and when I was finished I started the car and it had a hard time starting and had the slip, vdc and service engine lights all come on (btw the car had no lights on and was running fine before I did this) so I came back to it the next morning and found I forgot to plug-in the drivers side camshaft sensor and so I figured that’s what the code was about so I drove it up to oreillys to delete the code (it felt fine and didn’t have any trouble starting this time) but it ended up being P0051 & P1168 which are both codes for o2 sensors which I don’t think I messed with at all because I’m pretty sure the wiring is under the car but do you think it’s just a coincidence it’s failing right after working on the car or could it maybe just be pulling the codes for when it was running without the camshaft sensor creating a lean/rich AFR? I don’t really think it could be this cause the codes came right back after deleting them but if anyone has any advice or has had a similar situation I would greatly appreciated the help.
