ae7456t »
https://forums.nicoclub.com/ae7456t-u172554.html
Tue Jul 17, 2018 10:23 am
When I had problems with my transmission, I got a U1000 code...My initial issues were transmission related, and had them swap in a new transmission, but used the original Valve Body/TCM...This is when the U1000 popped up, with similar faults to yours (no manual mode, no gear shift indicator showing).
U1000, as I understand it, is some type of communication fault, most likely between your TCM and the rest of the smart parts in the car. In my case, the new transmission had sat outside, and, as a result, the connector plug that "tunnels" through the transmission housing to the TCM had become severely corroded to the point where the pins were crumbling. The fix was a simple as swapping out that connector and wire harness inside the transmission that connects to the TCM, then good as new.
Separately, I have also had experience repairing the TCM itself (due to the P1757 broken solenoid "finger"). From memory, transmission fluid gets all over, around, and in the TCM, so a crack in the plastic housing should not be a problem...More troubling is if the electrical board inside has cracked and a signal is not getting to/from the solenoids. Not sure if you have tried to open the plastic TCM case to inspect the board, but that might give you some more insights, as well.
