Hi to all :
I have a problem with mi 09 MURANO SL AWD ,i was cheeking the connection wires on the rear view mirror and by accident 2 wires get in contact the one from the ignition and the ground and i have a the check engine the dvc light are on
the car star but the ac is not working the shift it is stock in park and the steering wheel is hard .
the code that came out of the scanner is the U1000 NETWORK ERROR ,i check all the fuses and are fine I read that their is a common problem of grounding problem with this car but normally this wont cause driving problem but in my case i do have problem
Any of you guys have this problem before ?
any ideas?
thanks in advance
