Code scanner???
tireslayer325
Car: '93 S13 coupe
Can a '93 240sx be code scanned?? Does it have the plug for it or is it to old? Proly a stupid question but i couldnt find a straight answer. thanks
RiverCitySX
Car: 1993 Nissan 240sx KA-T
It will have the OBD1 connector. Nissan calls it consult. Located at the interior fuse block at the left kick panel.
I think you can also jump a couple pins there and a little light on the ECU will flash codes. Check FSM for procedure
and code reading/ defintions :) Places light Auto Zone or andvanced will NOT be able to check codes on that as they
can only do OBD2
