Code reading?
Fred D.
Car: Infiniti
1994 Q45I recently drove my car and it had a power loss and the check engine light came on for ten minutes then went off, and power returned. I want to check for codes, but I dont know how read the codes.I know it will blink at differnt speeds 0.6 second's for the first #, and 0.3 second's for the second #, in intervals,but how do I convert the blinks to numbers?
Rex
Car: None
Fred D. wrote:1994 Q45I recently drove my car and it had a power loss and the check engine light came on for ten minutes then went off, and power returned. I want to check for codes, but I dont know how read the codes.I know it will blink at differnt speeds 0.6 second's for the first #, and 0.3 second's for the second #, in intervals,but how do I convert the blinks to numbers?
uh ... count them _ _ _ . . . would equal a 33
Sorry.
Fred D.
Car: Infiniti
I removed the passenger side kick panel by the door, and see a square grey box labled C5 is this the ECU? I just dont see a light for reading the codes on it or the screw.1994 Q45
Q451990
You have to remove the screws that hold the ECU to the body to access the screw and see the LED.
Heath
Fred D.
Car: Infiniti
I removed ECU and did the test and it came back as 55, all ok. My car may be still have a faulty part, if the check engine light came on, even if was only a short period of time. What can I do next to find possible problems?
