enviro wrote:I have a 03 g35 with 73000 miles.. I cleaned the throttle body and gave it a tune up. The check engine light came on with the code PO507 Idler air control problem. The car runs and drives great it just i idles a bet higher than normal about 800 rpms. Does anyone know what i can do?
enviro
Never try to fix something that isn't broke.Not sure what you mean by tune up?Aside from oil, oil filter, air filter, cabin filter replacement, tire pressure check, tire rotation, checking fluids, you should be good for 100k miles.
Why did you clean the throttle body?
How often do you replace your air filter & did you replace it as part of your tune up? My air filter box gets dirty with bit of leaves, dirt etc & i vacuum and clean it out good. Did you inspect yours & clean it out?
Telcoman
