ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Tue Jul 12, 2011 10:19 am
During and after an oil change when an oil filter is also changed there is a possibility of a mess on the roadway, driveway etc. as the residual oil removed from the oil filter especially leaks onto the sub frame and cross members and most mechanics do not wipe this oil up or do a lousy job in wiping up so as time passes and you park in about the same place it looks like you have an oil leak.
You do, but not from the engine or engine related parts. The leak is all the residual oils coming down from the cross members, covers, and pieces of hardware under the car that happen to catch the dribbles of oil from mainly the filter.
It's a dirty job. It requires you to go under that dirty raised up car. Then with a wiper, clean everything. NO WONDER WHY MECHANICS DO NOT WANT TO CLEAN UP AFTER THEMSELVES. An oil/filter change takes time and then cleaning up takes time.
Many of us do all kinds of tricks to make less of a mess, but you will have to check for yourself or have a reliable trustworthy person check to see that the oil pan gasket is really leaking and if it is it must be tightened, wiped clean and observed for a while unless the leak is caused by missing parts, ripped parts of the gasket or a real loose pan.
You will need clothes that can get dirty
A bright light to see
A couple but at least a single ramp to drive up and raise the front.
DO NOT GO UNDER A JACKED UP CAR UNLESS IT IS ON SAFETY STANDS
Rags
If this is the first time under a car have someone with you.
