Thank you. It does do ABS. Does the Vehicle Speed PID come from the ABS Module via the wheel speed sensors?VStar650CL wrote: ↑Thu Jul 27, 2023 4:18 pmP1574 means there's a big difference between the transmission-indicated speed and the ABS-indicated speed. So the problem has to be in your ABS. The transmission is showing about the same speed as the ECM, and that gets to the ECM by way of the cluster. That should vindicate all three of those devices. If your scanner doesn't do ABS, you need to get a scan from one that does.
Thanks for the info. I checked ABS wheel speeds with GPS and they were matching speeds.VStar650CL wrote: ↑Fri Jul 28, 2023 4:01 amThe thing is, the speed readings should be tracking one another pretty closely, and they aren't. Nissan ABS's are very sensitive to reluctor issues, even one missed tooth will generate a wheel sensor code. The transmission isn't. Unless the OSS flatlines, the TCM won't generally notice, and missed teeth will only result in a reduced or fluctuating speed reading. It looks to me like that's what happening. Checking against a GPS should verify it, if the ABS speed tracks with the GPS but the OSS speed is off or unstable, that would be a smoking gun that the OSS is causing the code.
Yes, the only harness I touched was inside the trans. I didn't bother with unplugging the outside trans harness.VStar650CL wrote: ↑Tue Aug 08, 2023 5:50 pmP1721 is a flatline code for the same sensor. It means it isn't simply missing teeth now, it's also quitting completely for some period. That smells like wiring, and the only part of the wiring you would have touched is the stuff inside the pan. So I think you must have a problem with a cracked wire or a bad pin-fit someplace on the TCM subharness.
I probably should have used my wired Autel instead of my Bluetooth one for live data. What do you think the percentage is that the ECM is bad?VStar650CL wrote: ↑Sun Aug 13, 2023 8:56 pmIt's all over the lot, but that's probably a CAN artifact. The ABS throws codes if it misses even one tooth, or if there's the slightest wheel speed mismatch with the yaw and steering angle. If you think I'm kidding, try reversing sides on your rear wheel sensors for s#!ts and giggles. One of our techs did that once by accident when replacing a rear subframe, and the ABS lamp would light up the instant you went above 10 mph and turned the wheel about 2 degrees. The tiny speed differential between the two wheels wired opposite instantly triggered it. Since you have no ABS codes, the only way that can be the problem is if your ABS has completely lost its mind. I kind of doubt that. In your earlier FF plots, it was clearly the transmission speed that plummeted when the DTC occurred, not the ABS.
Both my Autel & Launch scanners read the PIDs with the same name.VStar650CL wrote: ↑Thu Aug 17, 2023 5:45 pmYour first FF's showed MTR and A/T, and I'd have to assume A/T is Automatic Transmission. Since that was the speed which was misbehaving on the graphs, I'd also have to assume the VSS in the transmission is the one acting up. The question is why, and with a new VB, the only things left are internal wiring or connectors, or mechanical wear in the output shaft. So unless your scanner is lying about the data sources, that's pretty clear cut and more data isn't going to help. On the other hand, if your scanner is confused about who it's talking to, then you won't be getting to the bottom of it without a better scanner.
Identifix has zero instances of P1574 being caused by a brake switch, and I've never heard of it either. It is common for gen1 Titan/Armadas and gen2 Armadas to throw C1142 from a bad brake switch, essentially blaming the wrong component (pressure sensor) for the problem. Aside from that, I have no idea what you could be talking about.akkoeis wrote: ↑Sat Oct 28, 2023 7:51 amThe most common cause of this code is a faulty brake pedal switch. Inspect the brake pedal switch for any visible damage or signs of wear. Make sure it's properly adjusted and functioning as it should. You may need to replace it if it's defective. Examine the wiring and connectors associated with the brake pedal switch and the cruise control system. Look for damaged wires, loose connections, or corrosion. Repair or replace any damaged components as necessary. After inspecting and potentially repairing any issues, you should clear the error code from the ECM's memory. You can do this with an OBD-II scanner or by disconnecting the vehicle's battery for a few minutes.
I am a professional technician, a Nissan/ASE master tech in fact. P1574 has nothing to do with the brakes, it's a speed signal. Identifix has over 250,000 professional subscribers and none of them have ever heard of P1574 being caused by an Armada/QX56 brake switch either. No offense, but please don't spout when you don't know what you're talking about.akkoeis wrote: ↑Sun Oct 29, 2023 10:25 amYou also mentioned a specific situation where the C1142 code might be erroneously thrown due to a bad brake switch. It's possible that in some vehicles or specific circumstances, a brake switch issue could lead to unexpected diagnostic trouble codes or issues, which is why a thorough diagnosis, often with the help of a professional mechanic or technician, is crucial to pinpoint the exact problem.
Yeah, turns out akkoeis was a sleeper cell spammer. He's been shown the airlock.VStar650CL wrote: ↑Sun Oct 29, 2023 12:35 pmI am a professional technician, a Nissan/ASE master tech in fact. P1574 has nothing to do with the brakes, it's a speed signal. Identifix has over 250,000 professional subscribers and none of them have ever heard of P1574 being caused by an Armada/QX56 brake switch either. No offense, but please don't spout when you don't know what you're talking about.akkoeis wrote: ↑Sun Oct 29, 2023 10:25 amYou also mentioned a specific situation where the C1142 code might be erroneously thrown due to a bad brake switch. It's possible that in some vehicles or specific circumstances, a brake switch issue could lead to unexpected diagnostic trouble codes or issues, which is why a thorough diagnosis, often with the help of a professional mechanic or technician, is crucial to pinpoint the exact problem.
