Code P0715
sunnydude
Car: '10 Rogue SL AWD
Just purchased a 2010 Rogue SL AWD from our neighbor. Has 82k. My daughter just took it back to college (300 miles away). She called two hours in to say it was having a hard time accelerating and the service engine light came on. Sent her to an Autozone and the code read was P0715 which is a speed sensor in transmission? She was able to complete her drive and I am planning to change CVT fluid and the sensor when she comes home in a couple weeks.
I haven't found many posts regarding this code. Is it indicative of a failing transmission?
Thanks.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Good news!
It’s NOT a sign of a failing transmission.
Sign of an incorrect air & fuel mixture somewhere.
I personally had problems with bank 1 twice, but not bank two yet.
I’m sure many here will make a suggestion for a solution. It varies. :mike
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
I found these after a quick search.
https://www.engine-codes.com/p0715_nissan.html
https://www.carobdcode.com/p0715-nissan ... alfunction
Here’s one that suggests you should clean or replace the gas cap.
http://p0715.enginetroublecode.com/nissan-altima
sunnydude
Anyone have clarification on whether there are two speed sensors on the transmission? I am seeing a primary and a secondary. :(
Return to “Rogue Forum”
