plundccre »
https://forums.nicoclub.com/plundccre-u156432.html
Mon Jan 15, 2024 5:22 pm
I have been trying to source the cause of my P0505 code on my 2001 QX4 2wd. Every time I clear the code, I drive it around to reset the ECM. After about 120 miles or so the P0505 code comes back on. This has been preventing me from getting my smog certificate her in CA and I haven't been able to register the vehicle in over a year.
The IAVC was replaced. I suspected that I had blown the chip on the ECM and sent it in for repair to a source I have used for electronics on several cars. He could not find anything wrong with the ECM. He had it for a couple of weeks and everything tested good.
What he told me was something that I have never heard of and have not been able to verify so I am hoping for some help here. What he said is that certain Infiniti/Nissan vehicles have an electronic engine mount (that adjusts its stiffness depending on RPM) that when it fails, can also give the P0505 code. He said that you can rev the engine to about 3000 rpm and then unplug the mount. this will lock it in a stiffer mode and, with it unplugged, it will no longer cause the P0505 code.
Does this make sense to anyone? Is there an electronic engine mount? When I look at a parts diagram, I don't see anything electronic. Just a mount with rubber and 3 bolts.
I would love it if the fix was this simple and c heap. Any thoughts?
