code p0420 .. seeking resolution asap!!
mitch01
Car: 2001 maxima
I own a max 01 . the dealer diagnostics said i have to change the front assembly tube ... Should i just install a y pipe and eliminate the pre cats . If anyone ever had this problem pls send any info as to how and wat they did to resolve this thk u in advance ... peace out
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
P0420 is "Catalyst System Efficiency Below Threshold (Bank 1)"So you either have a bad oxygen sensor or one of your rear bank cats is bad.
paluli
Car: Infiniti I30t
i had the same problem, i replace the bank 1 sensor 1. i bough my at oxigensensors.com part #250-23133 made by walkers. and the ses. has not coming on has been about 80 miles. since them
mitch01
Car: 2001 maxima
really appreciate the info .. but was your i30 a fed or a cal emissions? and secondly , is that sensor the one close to the firewall on the i30 thaks a whole lot for the info
paluli
Car: Infiniti I30t
Yes my i30 is cal imssion. and yes is the one close to the fire wall, the oxigensesors.com has the part wrong, but tell them you want the oxigen sensor part # 250-23133. thats if your maxima is cal. imssion. if not they will help you.
mitch01
Car: 2001 maxima
while changing the sensor i broke off the bung that the sensor screws in too....so now i have a hole in the manifold .... just my luck . so i ended up at my mec. We pulled the entire assembly off ...chopped off a bung from had on an old cat.he had lying around ... mig welded it on to my manifold .screwed on the new sensor ... reassembled and started ........ SES gooooooooooone .SWEET ...... It took about hour . and alot of swearing on behalf of my mec. But dude i must say thanks , really appreciate the info . thumbs up
