alexf20c »
https://forums.nicoclub.com/alexf20c-u34818.html
Mon Apr 12, 2010 10:06 am
the P0420 DTC is a common one, and it means your bank-1 catalytic converter is below threshold. that doesn't necessarily mean it needs to be replaced; it just means the computer thinks it's not working as well as it should. (this reading is obtained by the downstream bank 1, sensor 2 Oxygen Sensor.)
i get this code all the time. it comes on randomly, then disappears just as quickly as it came. it usually stays on a day or two for me. this DTC (diagnostic trouble code) does not affect engine performance. it does, however, affect the environment.
i've yet to replace my catalytic converters because like your mechanic said, it is very expensive. i just wait for the code to go away (the computer will retake the test and if you pass, it will turn the code back off). if you've got the money and you're anal about things, go ahead and have it replaced. like i said, the only thing being harmed is Mother Nature - not your truck.
for normal maintenance, at 60k miles, i'd recommend the normal stuff like air filter, fuel filter, oil change, plus things that make a basic tune-up. you'll want to change your spark plugs (use NGK OEM), distributor cap and distributor rotor. it wouldn't hurt to replace the PCV filter either. run a bottle of fuel system cleaner through the gas tank.
