spivic81 »
https://forums.nicoclub.com/spivic81-u27899.html
Sat Apr 16, 2005 12:43 pm
hello everyone, this is my first post... please help me (stuck)
just replaced head gasket, water pump, timing chain, guides etc... now i get this code p0340. I have set the timing to TDC of compression stroke, inserted the distributer following pictures from the chiltons manual and online info from alldata.com...
Anyways when i try to start after everything is in its place, i get a quick studder, then nothing,.... just motor turning over....
i have adjusted the distributer with a friend while key is turned, i have double checked the wiring.. could the chain be off a notch?
any info/ideas are very appreciated
