I just replace ignition coil 1 due to code p0301, and the code going away. However, another code just came up which is P0172. Is this meant the O2 sensor is bad? Has anyone deal with this code before? Where exactly is the sensor located, and where can I buy one? Thank you very much for readings.
V/R,
Mnguyen
