CODE: C170600 Cleared by mechanics
PHX08G37
Car: 2008 G37 Journey
I had a mechanic shop say they use the Consult III scanner, but didn't really. I found out from the tech they use a scanner equivalent to Consult III. They found code C170600 listed in three modules and cleared it cuz it was a flat tire fault and I have new tires. On www.engine-trouble-code.com it lists the code as Reverse Input Circuit, Throttle/Pedal Position Sensor/Switch A Circuit Intermittent.
Which one is right? Will Infiniti USA give me the information? Thanks Gloria: :blush:
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
C1706 is low tire pressure in the right rear. Don't believe everything you read on the internet. The FSM's are right here in Nico:
https://www.nicoclub.com/infiniti-service-manuals
PHX08G37
Thanks again VStar650CL.
Does the FSM list codes? How did you find it?
PS: Adorable puppy.
VStar650CL
Technical Expert
He was truly adorable, sadly he's gone to God's knee.
post6827865.html
Codes are always detailed in the FSM, but sometimes you need to hunt for the right section. TPMS codes are sometimes located in the Body Control section, but for your ride they're under Wheel & Tire:
https://www.nicoclub.com/service-manual ... 8%2FWT.pdf
PHX08G37
Thanks again.
VStar650CL
Technical Expert
:dblthumb:
