KDashy wrote:I'm aware that early 95's are OBDI, but assuming I dont run into any of those, shouldnt any late 95-98 5 speed ecu work? since theyre OBDII. Or is there differences that I'm unware of?
This is what a local 97 s14 tried using a 96 ecu.
"Found this pretty unknown info about obd2 ECU's. This is only if you care about turning off the CEL without pulling the light.
Its pretty impossible finding a 97-98 m/t ECU for people doing the 5-speed swap on their kouki s14. The alternative is finding a later 95' or 96' obd2 ECU and replacing the rear o2 sensor with a 96' 3-wire set up. These are the modifications needed to be done to the ECU harness.
http://jimwolftechnology.com/w...D.PDF
I learned this the hard way, I thought my evap vcv and rear o2 sensor went bad so i replaced the parts then overpaid for an 97 m/t ECU. Paid alot of money for useless parts but at least I didn't have to get under the car soldering the rear o2 sensor wires."
So basically I would try and find a 97/98 ecu to be sure your cel won't be on..
