Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Wed Nov 19, 2008 11:44 am
1986.5-1995 Nissan ECU Flash Codes(all engines)11 Crank Angle Sensor/Camshaft Position Sensor.12 Air Flow Meter/Mass Air Flow Sensor.13 Engine Coolant Temperature Sensor.14 Vehicle Speed Sensor.21 Ignition Signal.22 Fuel Pump.23 Idle Switch.24 Throttle Valve Switch.25 Idle Speed Control Valve.28 Cooling Fan Circuit.31 ECM.32 EGR Function.33 Heated Oxygen Sensor.34 Knock Sensor.35 Exhaust Gas Temperature Sensor.36 EGR Control-Back Pressure Transducer.37 Knock Sensor.38 Right hand bank Closed Loop (B2).41 Intake Air Temperature Sensor.42 Fuel Temperature Sensor.43 Throttle Position Sensor.44 ECCS Normal Operation.45 Injector Leak.47 Crankshaft Position Sensor.51 Injector Circuit.53 Oxygen Sensor.54 A/T Control.55 No Malfunction.63 No. 6 Cylinder Misfire.64 No. 5 Cylinder Misfire.65 No. 4 Cylinder Misfire.66 No. 3 Cylinder Misfire.67 No. 2 Cylinder Misfire.68 No. 1 Cylinder Misfire.71 Random Misfire.72 TWC Function right hand bank.73 TWC Function right hand bank.76 Fuel Injection System Function right hand bank.77 Rear Heated Oxygen Sensor Circuit.82 Crankshaft Position Sensor.84 A/T Diagnosis Communication Line.85 VTC Solenoid Valve Circuit.86 Fuel Injection System Function right hand bank.87 Canister Control Solenoid Valve Circuit.91 Front Heated Oxygen Sensor Heater Circuit right hand bank.94 TCC Solenoid Valve.95 Crankshaft Position Sensor.98 Engine Coolant Temperature Sensor.101 Front Heated Oxygen Sensor Heater Circuit right hand bank.103 Park/Neutral Position Switch Circuit.105 EGR and EGR Canister Control Solenoid Valve Circuit.108 Canister Purge Control Valve Circuit
There's the codes, but I don't know what ECCS Normal Operation means exactly. ECCS refers to the ECU itself, so maybe your computer is going bad.
