Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Sun Feb 19, 2017 9:27 am
Sounds like you've got some very common issues going on. EGR is almost guaranteed to be going out by now. Most people delete and either deprogram or resistor the connection.
Oil pressure sensor is also a very commonly failed part. The hole in the end of the sensor is so small that it can easily get gunked up. Some people have drilled the hole a bit bigger with limited success, but more often than not, a new sensor can fix that. Oil pumps on these don't go bad as often as some vehicles.
And lastly, the red light is telling you that you have a brake light out. There's a green sensor that reads the resistance of the tail lights somewhere in the interior panels on the driver side in the hatch. If you have swapped to aftermarket tails with LED's, there's nothing you can do. Otherwise, find the culprit bulb and replace. Also, if you have JDM tails, the bulbs they're shipped with have a different resistance than the stock bulbs and will also trigger the light. If you check all 4 brake bulbs and they're working, then it's probably one of the 3rd brake light bulbs. The 3rd brake light has either 4 or 5 bulbs, depending on year. If ALL of that checks out, clean the contact points on the 3rd brake light.
