nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Wed May 25, 2011 3:40 pm
The actual det sensor is below the lower intake plenum, that is gonna be impossible to get to without taking a bunch of stuff apart. The connector that you are looking for is in the open between the firewall and plenum, it will look like the same connector as the VTC solinoid connector. just look for the connector and follow it as it sould go toward the center of the engine. If you find one that goes to the valve cover, that is not it. It should be two prong and honestly just use electrical connector cleaner or wd40, spray that in the connector let it soak for a few min, then find a very small flat head screw driver and scrape off as much green crap that may be corroded on there.
Usually the sensor doesn't go bad, it's usually the wiring between the actually harness and the sensor that goes bad. The sensor usually breaks apart, but sometimes it goes bad, just not often. If you need to after you clean it, you may need to push the female part of the prong closer together so the male section has a good solid connection. I know I saw a write up somewhere on the net, maybe someone has it in their archives and can post it up, it even has pictures!!
Keep us updated!!
