Darius wrote:Dude I know how knock sensors work. What I'm trying to tell you about is my experience with them and the 34 code on the ECU not being specifically related to the knock sensors.
There is nothing to a knock sensor and that is why I highly doubt that one is faulty. In fact, of the three years I've bene on this board, I've never read a post of anyone's knock sensors being bad.
Happens all the time on the KA... Code 34 usually ends up being 1) KS subharness has a short or 2) KS itself is melted/bad. IIRC Code 34 means a problem with the KS itself or the wiring, that I recall I've never seen a code 34 thrown for the ECU detecting knock, in fact I think that's a separate code. Could be wrong though, wouldn't be the first time...
To test, use your mulitmeter on both ends of the KS wire, KS side and ECU harness side. Test for continuity, you should see extremely low resistance. If it's bouncing around or 0 then you probably have a short somewhere.
If you search inside the FSM you'll find the specs for the knock sensors themselves. You can use your multimeter again to test each ones internal resistance. I want to say on the KA the knock sensor should measure about 500kohms but look it up to be sure.
