Sallion55 »
https://forums.nicoclub.com/sallion55-u252889.html
Sun Jul 05, 2015 9:25 pm
Hello everyone, I posted on here about a month ago with a few problems I was having with my car and I just wanted to update on them and bring forth the new problems I am having.
1: when it cold starts sometimes the rpm bobs between 100-900rpm, and almost cuts out
2: The car seems to idle lean, when I'm driving it seems to be fine and in stoich, and when I'm pinning it it just goes into rich, so I was wondering if it idling lean is bad and what I can do to fix it
3: when in 2nd and 4th gear, I can feel constant rubbing against the shifter, it is pretty light and it doesn't sound or feel like grinding but I could be wrong. When I'm standing still it's fine, and you don't feel the whole shifter shake but you can feel the vibration come from lower and you can slightly hear it.
I thank NolimitZ32 and DCaff300ZX for there help as I cleaned my IACV and electrical connectors which solved my first problem, and I put in a different shifter which solved the third problem. The new problems I now have are:
1: I have error code 34, I am pretty sure it is my knock sensor because I tested to make sure all of my cylinders are firing after seeing the code. It is weird though because my car runs VERY poorly sometimes, and then mostly regularly other times. During the rough times it idles fine but the car seems to shake a little bit, and under any sort of low rpm acceleration (under 4000) it is VERY boggy and the car sounds completely different from what it normally does. Other times though, it runs close to normal, but you can feel it studder very slightly when at a constant rpm. When it was running rough today it started running extremely lean, not just idling lean, but very lean under acceleration as well and I got worried. Then. after 5 more minutes of driving the car seemed to just switch over to running better and it ran in stoich like it normally does
2: Since I bought my car (4 weeks ago), it has smoked when it idles but does not smoke while driving and sometimes after a long period of driving (over a hour), it wont smoke when idling. Just very recently (in the last 2 days) it has been worse, and sometimes smokes while i am driving and under acceleration. Its weird because sometimes the smoke seems blueish, and sometimes it is white. Today while driving with my friend behind me, he told me it was smoking blue for about 5-10 minutes. then stopped randomly after being at a red light. This issue has greatly confused me because sometimes i know it is burning coolant from the smell, and sometimes i know its oil from the blue colour, my engine was rebuilt at 122000 km but that was also in the year 2000. It has 151000 KM now. So I am worried it is my piston rings starting to go, and that my head gasket has a crack in it, but I am taking guesses.
3: There is a constant gear moving sound coming from under my shifter since i replaced my old one. The grinding stopped in 2nd and 4th and this is more of a constant sound that can be heard even when idling and standing still so I know it is not something to do with my drive shaft
4: The car is idling lean still , and I know I have a vacuum leak, so I was wondering if anyone had any tips on finding vacuum leaks
THANK YOU VERY MUCH for any feedback
