Back to problem got code 34 not long after we got car back together ,after researching detonation sensor issue i decided to do the relocation kit . My car was not going into safety boost and still ran good when at operating temperature . I put the kit on following bernies instructions and after resetting ecu no light for about 15 miles then it came on again . I had a bad injector in no 2 cyl before replacing all of them so brad said to do compression check to make sure i didnt have a bad cyl problem . Today i did compression check regapped plugs as a few were gapped improperly and heres my results
No 2 152 psi
no 4 162 psi
no 6 165 psi
no 1 168 psi
no3 170 psi
no 5 170 psi
put back together let car warm up and drove down road about 5 miles , Jeez ran like a scalded dog pin me to my seat ran better than ever ,no code called brad to tell him news and while
idling in driveway light came on cant figure it out allready checked connections harness etc . baffled any help greatly appreciated
Car runs very strong except when cold if thats any clue thanks again
