code 33, runs like s***, aem uego. HELP!!! (video)
seattlebmxs13
Car: 91 240sx s13
alright so heres the story.
i parked the car at a buddies house and when i fired it up to drive somewhere it just ran like absolute crap, idle like s***, no power etc...
ecu is throwing code 33 (O2 sensor code) so i decided to toss in the new sensor and hook up my AEM UEGO wideband gauge at the same time.
I've checked quite a few different things and i'm pretty sure its still the o2 sensor (I reset the ecu and its still throwing the code). It also gave me a code 45 ( leaky injector) when it first started messing up, but i pulled the fuel rail, no leaks.
I guess the UEGO system might not be hooked up right but i dont know how. power and ground are fine and i'm running the white wire from the gauge to pin 19 on my ecu connector. I have tried all 5 modes on the gauge, no difference.
anyone know whats up? thanks in advance
I need to get this b**** running again so i can get emmisions done and go ka-t...
heres a link to the video, help much appreciated.
http://www.youtube.com/watch?v=FIFKo3_iiuk
Modified by seattlebmxs13 at 3:40 PM 4/8/2010
edit: car runs the same with the o2 sensor disconnected, so i think thats the issue. just cant figure out what i'm doing wrong.
Modified by seattlebmxs13 at 6:24 PM 4/9/2010
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Have you checked the engine with a vacuum gauge yet?
seattlebmxs13
Car: 91 240sx s13
have not done that yet. would a vacuum leak cause it to suddenly run like crap though? I'm pretty sure the issue is the o2 sensor because it runs exactly the same with it disconnected...
seattlebmxs13
Car: 91 240sx s13
well to update, i tossed in a new oem style universal sensor and hooked up all the stock wiring and I got nothing... still runs the same when disconnected too.
Shouldn't having the o2 sensor disconnected affect how it runs?
I also think I've found a dead injector, so I'll be replacing that once i get to the junk yard. Would this alone cause my problem? I tossed one of my new 550s in just to see what it would do but it didn't really seem to help anything. its definitely the injector though, I swapped it with the one next to it and pulling the harness on that one still did nothing...
freerebel1993
Car: 1990 240sx ka24e
try advancing the timeing a little and check your fuel filter(blow threw it) and check the sock on the fuel pump
Chris28
Car: 92 s13 KA-T
The UEGO is a wideband, it shouldn't hook up to your ECU at all. Check your o2 sensor wiring with a multimeter.
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
Did you put the uego in where the factory o2 was and throw the factory one out and leave the harness unplugged???
