RubyRed300ZX »
https://forums.nicoclub.com/rubyred300zx-u159844.html
Sat Oct 19, 2013 9:11 am
The code merely tells you that a condition exists which is causing the O2 sensor to read abnormally high or low. If you go to the second stage of testing (and watch the progression of the flashing indicator light), you can determine if that side of the engine is running rich or lean. However, you've already said that it's running rich. So, probably nothing wrong with your O2 sensor, which you said is new. More likely a bad injector in that the problem is just on one side. Use a multimeter to check the ohms on the injectors for 2, 4, and No. 6 cylinders.
