8-bit »
https://forums.nicoclub.com/8-bit-u43277.html
Sun Oct 01, 2006 9:28 am
When you remove the EGR ****, you have an EGR Temperature sensor in your intake manifold between runners 2 and 3. It looks like a nut with a wire coming out of it. There is a connector in your harness that has 2 wires related to that sensor.
If you put a 1/4 watt, 100k ohm resistor in the path of those wires (instead of the sensor), it fixes the code. The resistor should cost around 25 cents.
I have this same problem, but mine is much stranger... I have a non-california wiring setup, but my ECU fried and I swapped in a California ECU. So now it throws the code and I cannot get to that wiring harness because it does not exist..
So i have to put my resistor ON THE ECU. Or at least in the pins of the main wiring harness-to-ecu. Haven't done it yet, but i'm sure it'll work out fine when I do.
Cheers,8
