NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Wed Apr 27, 2005 3:09 pm
All that code means is the temp in the egr passage is not dropping suffeciently to indicate EGR flow when the vaccum is expected to be supplied to the EGR valve.
A few things can cause this, oddly enough I had to do a full work up on a 92 vert today, He has the same code...lol Anyhow If the BPT hose is burnt through it will not allow back pressure to push up on the diaphram of the BPT closing its internal vent to atmosphere sending the vaccum to the EGR. So check the little hose under the BPT, If the hose is soft and collapsed or burnt through replace it and drive the car a couple blocks and see if the light goes out. If the hose Does not appear to be an issue,slide you fingers up under the EGR valve while the car is idling and push up on its diaphram, the engine should stumble to a stall or drop to where it almost dies. If this doesnt happen then you got passages plugged and need to clean them out[no fun]. If that checks out then you need to do vaccum tests on the BPT with the car running and just off idle[so the hard idle contacts open in the tps] the hose coming from the solonoid should have vaccum. If thats ok hook it back up to the bpt and hook your vaccum gauge to the hose hooked to the EGR from the BPT now goose the throttle and watch your gauge you should see momentary bursts of vaccum on the gauge, should be able to clear 5Hg on each burst. If this doesnt happen you need to test the BPT. That should get you started if all those check out [ in that order] Hit me back and I will give you some more tests that can be performed for the BPT. I think you will find your problem with what I gave you though.
