DougQ45 »
https://forums.nicoclub.com/dougq45-u513.html
Sun Jan 11, 2004 9:07 am
A consult is $85 in Los Angeles, so the $68 part is cheaper than the diagnosis. The only probelm is when you are wrong on your educated guess---then you are out the price of the part. Wes try this, 1) hook a simple 12V light up to one terminal on the solenoid and one end on positive side of battery cable, 2) hook up a wire to the other terminal on the solenoid run wire to negative side of cable. If your 12V lights, you have power to the unit. Now, disconnect the 12V light to the solenoid, and listen for the solenoid to cycle/shut. Repeat several times, and make sure it cycles each and every time. If it sticks or doesnt activate, then that is likely the probem, and also the cause of the CEL. With the bad one I had to replace, it would NOT cycle about every 4th test. Just some dumb bankers thoughts.
