onecrazyfoo4u »
https://forums.nicoclub.com/onecrazyfoo4u-u42462.html
Thu Mar 20, 2008 11:36 am
So ya, I changed out my knock sensor a couple weeks back because of the code 34, and I check it again and today it's a code 31 (ECM). Is there any possible way that these 2 can be related? I've never had the ECM code pop up, and the car runs just fine.
What are the symptoms of running a bad ECM? Will it pull back timing, and reduce power, like the bad knock sensor did? Car runs just fine, it seems to be lacking a little, but I think that's just me getting used to the boost I'm running. Let me know what I need to do!
On a side note, my ecu isn't bolted up on the passenger kick panel or anything, it just kind of falls out when you pull the plastic cover off. Is this bad, will it cause any harm if it's not bolted down tight? Thanks alot!
