Code 21 -Ignition Signal / Where to begin?
DaydreamDrifter
Car: 90 240sx 00 Altima
Any suggestions on what to look for?
Chezedik
Car: 1991 Nissan 240sx
coil, module, cas, distributor, wiring, etc.
tiger
First i'd look at my wiring... just make sure that it's not cut or frayed anywhere... make sure there is a good connection on EVERYTHING. I had an ignition signal problem and a wire was loose to my aftermarket coil. I got rid of that sum ***** and put the stock one on. make sure all your grounds are there too. Your ignition coil could have gone bad. Oh BTW. C if you're getting spark and write back.
240needinghelp
my car is doing the same thing and the mechanic is stumped! we are changing the harness to see what happens.
