streetspirit7 »
https://forums.nicoclub.com/streetspirit7-u14716.html
Fri Oct 29, 2004 6:09 pm
My 240 won't start, It turns over I'm getting spark, and fuel. I pulled the ecu codes and came up with 21, 34, 82. I had the distributer out and put it back in, i think I did that right. I turned the engine over till I felt air come out of the #1 cylinder, then set it to top dead center mark on crank, then set the distributer to #1 plug. is this right? If it is why wouldn't she start? It ran before I pulled the distributer. I've searched but not found a problem like mine. I thank you for your help in advance.
