code 1490 ???? help
hangout
Car: 2007 FX35,, 2016 Q70L
Hi: I have a 2001 Sentra 2.0 SEthe engine light came on last week.my friend check it for me, the code is 1490. but we couldn't find what it means form the book.we shut it off, but it came back on after I made the first turn out side the shop
any one had this before? expensive to fix?please let me know..
thanks
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
zerothread/298476
Look under b15 problem areas, there will be a list of engine codes.
ABNRML4U
Car: Nissan B13
That means SIR! that your NISSAN is telling you how many Women you have been with in the back seat.
hangout
Hi: Thanks for your infor, I went check the link, but as what I said , we couldn't find P1490 stands for..
nametakennow
Car: '06 MINI Cooper S
I can't find 1490 listed anywhere, you sure that was the code?
Try the FSM, link in my signature.
ABNRML4U
Car: Nissan B13
So, is it fixed?
hangout
No, the light still on.my guy use the computer to check it few times, still the same code. P1490he also called his part supplier to find out, but their computer couldn't find that code also...the car still drive good. what else I can do
hangout
I did search on google, someone had the same code before, he said that;s the bypass valve malfunction, it's behind the Lf/Rear wheel.the connector was wet, so need to replace the connector to the bypass valve..anyone has any idea about this? is it a big job? $$$ ?
I found this alsocode P1490 = Vacuum Cut Valve Bypass Valve (Circuit)
any idea???
Modified by hangout at 7:16 PM 4/22/2009
Modified by hangout at 7:20 PM 4/22/2009
nametakennow
Could be that the valve is sticking. It's a fairly common issue with the evap system, though I don't think this is the same thing (different code number). Try lubing the valve or replacing it.
Have you had your VIN run for the ECU foam recall?
