BurntTimber »
https://forums.nicoclub.com/burnttimber-u99412.html
Thu Jun 25, 2009 3:59 pm
As an additional note to my lazy response, code 0456 or 1456 can be any of the following:
Fuel filler cap, vacuum connection, fuel tank, fuel tank pressure sensor, evaporative bypass solenoid, evaporative two way valve, evaporative control canister vent shut valve, evaporative control canister and evaporative purge control solenoid.
Needless to say, the only easy fix there is the fuel cap, but not likely that is your problem. The code has just recently come back, I've tightened the fuel cap one more time and cleared the code. If it comes back again, I'll know that it requires diagnosis. If it comes back, I'll post on the journey this fun little code takes me on.
