code 138
mds7480
Car: 2002 Nissan Maxima
Yesterday we had 2 sensors replaced. They were 138 and 139. Just a short time after my car was fixed the SEL came back on. I took it for a reading and it showed 138 again. What needs to be done????? I have to get my new tags but can not get emmission tested with this light on. Help....
Dattebayo
P0138 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1)
P0139 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 1)
You should probably post in the Maxima section. Gen Chat isn't the right place for this stuff...
300ZXttZMAN
Agreed. I'm moving it to the Maxima section with a shadow topic in place.
Welcome to NICO!
darylzero
mds7480 wrote:Yesterday we had 2 sensors replaced. They were 138 and 139. Just a short time after my car was fixed the SEL came back on. I took it for a reading and it showed 138 again. What needs to be done????? I have to get my new tags but can not get emmission tested with this light on. Help....
do a search for code 138 and you will find some topics on this
mds7480
Trying to find replies t this post but don't know how.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Both fault codes refer to Bank 1 Rear O2 sensor (HO2S2-B1). Did they replace the faulty O2 sensor or may have replaced the wrong one. Bank 1 is towards the firewall while Bank 2 is towards the radiator. Bank 2 Pre-Cat is oriented vertically and can be seen between the engine and the radiator, including the front O2 sensor (HO2S1-B2). Did you use Bosch or NGK/NTK sensor or something else?
The Bank 1 Pre-Cat is horizontally mounted belowthe engine with the HO2S2 sensor located in front of it. You also have to check for air intake leaks. Refer to the link below for more information, starting on page EC-249 for P0138:
http://www.nicoclub.com/FSM/maxima/2002/EC.pdf
