MN-Gopher1 »
https://forums.nicoclub.com/mn-gopher1-u31434.html
Sat Oct 08, 2005 6:25 am
Thanks!!You are correct. I did find that TSB. I don't believe that the coils have been changed out as I've had the vehicle for all but the first 27,000K miles. I suppose the dealer will be able to pull up a VIN service record as to what has been replaced. I have had the vehicle at the dealer before but they have never mentioned any service/replacement of the coils. If you don't ask about service bulletins, aren't they suppose to mention it?
I spoke to the service manager yesterday(Friday) before they closed. He didn't mention a service bulletin. He did tell me to reset the MIL and it may come back with a different code that may identify which coil(s) are causing the light to come on. As it stands right now, P1320 (Ignition Signal Primary)means replacing them all, is what he told me. If needed, I will be ordering them from Everything Infiniti as they are much less money(around $56 a piece) Still alot of money though. Everything Infiniti has been very good as I have bought 02 sensors from them and they have been easy and quick to order from.
If they are still the original coils, will the dealer replace them for free? Does the milage matter? I have 124,000k on this car. Is the grey dot on the coils visible without unhooking the electrical plug? I recently replaced the plugs and don't remember seeing any markings.
Thanks alot. You guys are a great resource!
