I have an 5 Sp 89 240sxDuring the winter my ECU indicated a problem with the Engine Temperature Sensor (AKA Code 13). Being that it is HOT and tough in the great outdoors I have chosen to deal with that sensor now.
Over the past while my Sensor consistantly reads at Half way and varies very slightly. It will immediately indicate half way despite the car having sat for long periods of time and I do not feel it is reading correctly. I do not want my car to overheat as I already know my radiator is less than ideal. If it is running too hot I need to know the temperature is being read correctly.
I have changed the sensor but have seen no change in the gauge and don't feel this has solved my problem. I will check the codes again this weekend, however, is there is something else I should do regarding code 13?
Please keep it simple...I'm no mechanic
Otherwise..Happy Weekend! My car is Falling Apart! ARGH
