Lately I've been having this stumble as I shift into 2nd gear in my '91 240sx. So I pulled the codes and I get the Coolant temp sensor circuit. I check the resistance on the sensor but it is in spec...Then I check the wiring. 4.9V at 'A' and ground and I get a beep noise for continuity between 'B' and ground. What should the resistance be for continuity???Is ther something I missed? Could there be a loose pin on the ECU?
I unhooked the sensor and went for a drive. It seems the stumble has disappeared since I believe the ECU goes into safe mode for 80C..Should I replace the sensor anyway even if it reads fine? .349 k ohms after a long highway drive.
Thanks
Modified by NateDogg at 9:50 PM 4/19/2005
