Code 12 Maf Problem
danielwka
Car: 1993 240sx SE
This morning my 240 started up just fine but after about 2 seconds it started running like crap. Feels alot like a misfire. It will drive but it really struggles at every rpm. It reminds me of the time I forgot to hook up the maf a few years ago.Big suprise I'm getting trouble code 12, "maf".I took it out and it looks like it's in great condition, The source voltage is good, the ground is good.With aux power it reads .3v, idle reading is 1.2v. Seems ok, but the last test threw me off. when reving the engine I'm supposed to see the voltage climb from the 1.2v idle to about 4v at 4k rpm but I can rev it as high as 6k rpm and the voltage will only go up to about 3.3v.I know this probably means the maf went bad but I'd like to know if replacing it will fix the problem. Like I said, at idle the maf reads 1.2v which is good but the idle is seriously rough. Does that suggest it's something else?Suggestions appreciated.
plugs & wires are finealready cleaned mafplugged injector?? (would this throw a code?)
dkdeleon68
Car: 1991 240
disconnect your battery for an hour or two to reset the ecu. then before reconnecting the battery check you maf plug for proper fit, if all is good reconnect the battery and it should recognize the maf.
danielwka
Car: 1993 240sx SE
Code reset, no change.
Does anyone know how it could be throwing a code 12 at idle when I can read the maf wire at the ecu to be 1.2v? Doesn't make sense.Thanks.
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
at seeing these air flow meters more than once a test OK but would trigger the ECU code 12 I try another air mass sender and the problem is gone. Do make sure your connections are not corroded or damaged. Sounds like you can do hit the point of when the manual says try known good part always loved that little phrase in the factory service manual>>>>>>
danielwka
Car: 1993 240sx SE
Been looking for another maf all day. So far only one wrecking yard has it, $135 - yeah right.
Anyone in the Portland, OR area who wants to sell me one for a reasonable price would be great. Don't want to wait for shipping.
480sx
Car: 1996 Pearl White 240sx
Iv got an extra 3 prong MAF, early series KA or SR. The later ones are 4, the extra for a intake air temp.. Do you need that one or the newer style?
danielwka
Car: 1993 240sx SE
4 prong. Thanks anyway.
sb
Car: 1993 s13
480sx wrote:Iv got an extra 3 prong MAF, early series KA or SR. The later ones are 4, the extra for a intake air temp.. Do you need that one or the newer style?
How much you want for the 3 prong MAF, just found out I need one as well.
Thanks-
SB
480sx
50 shipped for the MAF sounds resonable to me, what yah think? I can throw it up on ebay or somthing.
sb
Car: 1993 s13
Hey thanks for the response, I found one already though. Thanks.
SB
sharkerio_coupe
Car: 1991 Nissan 240sx Coupe Chuki Shark
1989 Nissan 240sx Coupe
1999 Nissan Maxima
1997 Nissan 240sx Kouki
1991 Nissan 240sc Hatch
1990 Infinit M30***
HELLOOO
I have the same problem...have you solve it?
I put in a working MAF and no change. Is it supposed to make a difference right away? I havent tried the ECU reset. I will today. Also, someone told me after install the new MAF to start the engine a number of 23 times for ECU to adjust or somethin...is this BS?
i also changed the throttle sensor, coil pack, and carbon catch can...all before reading the code. AND I checked for all the grounds and theyre there.
n still I get black smoke...almost blueish. rough idle or shut off and wouldn't be able to rev past 2500. I replaced my stock intake, and still the same except i can rev past 2500, not a healthy rev though....
any advise from the gurus? please i need a car!!
I HOPE THIS ADDS TO THIS THREAD< I DON"T MEAN TO THREAD JACK.
Gabes13
Car: rb20det s13
this is 2 years old...
im sure he wont mind if you jack his thread
sharkerio_coupe
1999 Nissan Maxima
1990 Infinit M30***
oh hahaha
wellll how did he solve it?!
