Code 11 Crank Angle Sensor after oil change
snobrder
Car: 1991 Infiniti Q45
Hi guys i just did my first oil change on the q and it was a pain in the ***....everything went fine but i started the car and had a CEL so i checked the ecu and i have code 11? anybody know whats up
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
So tell us did you change the filter form the top or the bottom as specified by the manual?
sublime187
Car: 2000 Q45 Anniversary Edition 101k
Is it also necessary to change the oil filter from underneath on the FGY33? The minimum wage pit monkeys insist it's easier to do topside...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
And that is why they are minimum wage pit monkeys.
It is really good for an owner to have someone familiar with a FGY33 or G50, Y34, Y50 or F50 to change the oil and filter and crush washer which you supply so they can observe the underside and point out failing or soon to be failing components.
sublime187
Does a topside oil filter change on an FGY33 risk certain damage? At least I can tell them to be careful to watch for X next time...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
In the best case, frequent conncetions adn disconnections will wear the connections faster. With minimum wage pit monkeys, be prepared for worse. Have them do it correctly. It's kind of a vetting procedure for incompetent help.
snobrder
ok i fixed it....i checked the fsm and found the cps and found it was just a loose connection.
goody90q45
Car: 1992 Infiniti Q45 (sold)
maxnix wrote:So tell us did you change the filter from the top or the bottom as specified by the manual?
Except for the few of you that still have the under-engine shield I'm not sure it saves the lube techs any time to change the oil filter from the top since most have a pit or lift to work under. They're more interested in selling you an air filter and will remove the air box lid without any thought, probably without disconnecting the MAF connector and tugging on the remaining length of the ECU harness and everything else connected to it in the process.
I change my own oil (on all 4-5 of my cars).
snobrder
ye
maxnix wrote:So tell us did you change the filter form the top or the bottom as specified by the manual?
yea actually i did
