code 11 CAS
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
i am throwing a code 11
symptoms are... the car revs slow and won't go above ~3k rpms, just gets there and holds.
the car idles fine at at ~800rpms
would a bad CAS cause those symptoms, and also, are there anything i can do to check the CAS short of replacing it with a new unit, and if so, is there a USDM cas that interchanges with the CA18
also, is there anything that may give a false code 11 or something i can look into that would make the ECU think my CAS is bad.
also, does anyone have a known good CAS for sale?
thanks
-terry
