patchan »
https://forums.nicoclub.com/patchan-u21063.html
Sat Apr 09, 2011 1:13 pm
Hi Everyone,
I have a s14 sr20det swap into a 95 240sx. Motor was previously running, but does not start up anymore. Car cranks, but doesnt turn over.
So far, I have tested with 3 different ignitor chips, and 3 different CAS.
Seems that I have fuel but no spark at the moment. Checked for power and ground for the coil packs, all read ok. Swapped out for another set of coilpacks I had, still no spark.
I was running a powerFC, but switched back over to my stock ecu and running the consult port. Using ECUTalk, I was getting a code 11 for CAS. When trying to start the car, I can see the disc spinning since the cover is off. I also ran new signal wire straight from the cas to the ecu. Nothing seemed to have worked so far.
Does anyone have any suggestions or ideas on what might be the problem? Thanks in advance!
