Code 11 and the engine is flooding itself.
HybridOne
Car: swaps
So if i start up the car it runs ok for a sec and then starts dropping rpm and studders then dies. it won't start back up. then i pull the fuel pump fuse and turn it over and it starts for a sec the dies because of no fuel. then i plug the fuse back in and it starts right up. and then studders and drops rpm and eventually dies.
i can't get timing to 15 degrees. it's way to advanced. also, i KNOW cam timing is on, maybe the CAS is a tooth off.
But the engine code for the CAS is odd...why does it toss the code? bad voltage? wrong voltage? bad sensor?
Nismo_Freak
Car: 89 Nissan 240SX
Reinstall the CAS.
HybridOne
Car: swaps
re-installed and still doing it. Tried moving it back a tooth and forward a tooth...no worky. Code is gone though. now just a knock sensor code (and i have no sensor, so i'm sure it'll be fine)
BUT my safc is reading REALLY low voltage on TPS...like 0.14 on closed and 3.4 on WIDE open. So i need to adjust that and see what happens.
I am going to post the longest most in depth troubleshooting thread known to man if i ever get this thing running.
geh
