Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Jun 25, 2013 4:55 am
You pulled the codes correctly.
Do you know what the timing is sitting at?
It's not a common thing to see die on an SR, but it's not unheard of either. You can test for continuity between the two sensor wires at the CAS plug and their respective ECU pins if you want to be sure it's not an issue with the wiring. The power wire should be seeing battery voltage as it is powered by the ECCS relay. And lastly, confirm the ground is good on the plug.
Past that, check that timing isn't astronomically off and consider swapping in a known good CAS to eliminate it as a variable.
As for the MAF, try cleaning it first. If the hot wire is coated in crap, it could be causing your intermittent issue on the signal wire. Also check for continuity on that circuit before you go running a new line. It's possible at the solder points for your MAF extension that something got junked up. It's a shielded line, make sure that the shielding didn't get soldered in with the signal line.
